Go Back   Detroit Racing Forums > Technical Discussion > The Bodyshop
Unread 01-15-2010, 04:09 PM   #1
Default Removing old lettering??
Unread 01-15-2010, 05:48 PM   #2
565bbccarbed
565bbccarbed's Avatar
565bbccarbed I need rep points!
QUESTION ? getting painted lettering off old race car / does the oven cleaner work or myth .Then second how is a good way to clean old lexan windows (like from stickers and nos purge spay) .Thank you for the input if any
565bbccarbed is offline   Reply With Quote
Unread 01-24-2010, 07:34 PM   #3
supernotch90
supernotch90's Avatar
supernotch90 I need rep points!
I would have someone do it that has removed them, I would use a solvent try it in a not so noticeable spot see if it works if it does then great, after its all off would wheel it out and put a nice coat of wax on it.
As for the lexon a wheel with some ultrafina or swirl remover should work as well. Just gotta be careful not to melt the windows.
Thats how i would do it. Hope this helps.
supernotch90 is offline   Reply With Quote
Unread 04-05-2017, 04:45 AM   #4
michael06
michael06 I need rep points!
If it is vinyl lettering, you can use eraser wheel without damaging the paint.
michael06 is offline   Reply With Quote
