Go Back   Detroit Racing Forums > Technical Discussion > Technical Articles and "How To's"
Unread 03-10-2005, 11:35 PM   #1
Default Wheel vs. Tire width selection chart
Summary
Each tire has a specific rim width range on which the tire can be mounted. Failure to follow rim width recommendations may result in poor tire performance or possible wheel and/or tire failure.
Details
Below is a quick reference chart listing each tire size and the acceptable rim widths for that size. Choosing a wheel near the middle of the range will give a balance between ride quality and handling. A wider wheel will improve handling at the expense of ride quality, while a narrower wheel will improve ride quality at the expense of handling. Consider these compromises when selecting wheels.
Metric Rim Widths
Aspect Ratio Metric Size Designations Approved Rim Width Ranges
35 Series 275/35R17 9.0-10.5
335/35R17 11.0-13.0
345/35R15 11.0-13.5
40 Series 285/40R15 11.0-13.5
215/40R15 7.0-8.5
245/40R17 8.0-9.5
255/40R17 8.5-10.0
265/40R17 8.5-10.0
235/40R18 8.0-9.5
45 Series 195/45/R15 6.5-7.5
215/45R15 7.0-8.5
255/45R15 8.5-10.0
205/45R16 7.0
225/45R16 7.5-9.0
245/45R16 8.0-9.5
215/45R17 7.0-8.5
235/45R17 8.0-9.5
255/45R17 8.5-10.5
50 Series 175/50R13 5.0-6.0
195/50R14 5.5-7.0
205/50R15 5.5-7.5
215/50R15 6.0-7.5
225/50R15 6.0-8.0
195/50R16 5.5-7.0
205/50R16 5.5-7.5
225/50R16 6.0-8.0
235/50R16 6.5-8.5
215/50R17 6.5-7.5
55 Series 205/55R14 5.5-7.5
185/55R15 6.0-6.5
195/55R15 5.5-7.0
205/55R15 5.5-7.5
205/55R16 5.5-7.5
225/55R16 6.0-8.0
60 Series 185/60R13 5.0-6.5
205/60R13 5.5-7.5
185/60R14 5.0-6.5
195/60R14 5.5-7.0
205/60R14
195/60R15 5.5-7.0
205/60R15 5.5-7.5
215/60R15 6.0-7.5
225/60R15 6.0-8.0
235/60R15 6.5-8.5
65 Series 185/65R15 5.0-6.5
195/65R15 5.5-7.0
205/65R15 5.5-7.5
215/65R15 6.0-7.5
70 Series 165/70R10 4.5-5.5
175/70R12 5.0-6.0
175/70R13 5.0-6.0
205/45R16 7.0
185/70R13 5.0-6.5
185/70R14 5.0-6.5
195/70R15 5.5-7.0
205/70R14 5.5-7.5
185/70R15 5.0-6.5
205/70R15 5.5-7.5
215/70R15 6.0-7.5
82 Series 155R12 4.0-5.0
155R13 4.0-5.5
165R13 4.0-5.5
175R14 4.5-6.0
185R14 4.5-6.0
165R15 4.0-5.5
P-Metric Rim Widths
75 Series P205/75R15 5.5-7.5
P215/75R15 5.5-7.5
P225/75R15 6.0-8.0
P235/75R15 6.0-8.0
80 Series P155/80R13 4.5-5.5
P165/80R13 4.5-6.0
P175/80R13 4.5-6.0
P185/80R13 5.0-6.5
35 Series P315/35R17 10.0-12.0
40 Series P275/40R17 8.5-10.0
50 Series P215/50R13 5.5-8.5
P235/50R13 6.0-9.0
P245/50R14 6.5-9.0
P225/50R15 6.0-8.0
P295/50R15 7.5-11.0
P225/50R16 6.0-8.0
P245/50R16 6.5-9.5
Unread 10-12-2007, 12:59 AM   #2
Zirotti
Zirotti I need rep points!
These are nice tools as well...
miata.net/garage/tirecalc.html
f-body.org/gears/
rims-n-tires.com/rt_specs.jsp
2007 Chevy Trailblazer SS [tuned, intake, exhaust]
Zirotti is offline   Reply With Quote
Unread 10-25-2007, 08:29 AM   #3
Default Ok guys ????????
Looking for new set of tires for next year for track use.Drag slicks or Drag Radials ???????
