Go Back   Detroit Racing Forums > Technical Discussion > Technical Articles and "How To's"
Unread 04-01-2007, 11:46 AM   #1
blue83z
blue83z's Avatar
blue83z I need rep points!
Default Driveshaft alum vs steel
What are the pros and cons on aluminum vs steel driveshafts.I know alum you have to go bigger on diameter cause not as strong as steel,and I know it absorbs vibration,but does it absorb horsepower too?
blue83z is offline   Reply With Quote
Unread 04-02-2007, 01:24 AM   #2
Cobra Jay
Semper Fi
Cobra Jay's Avatar
Cobra Jay I need rep points!
Pros-stronger and lighter than steel. Less rotating mass frees up hp and tq to the wheels. Shaves weight from the car.
Cons-can be expnsive in custom made applications.
Carbon fiber is also used to make driveshafts.
1996 SVT Cobra coupe: Vortech S Trim, Kooks LT headers, 4R70W and a few other goodies.
DD- 2011 F150 FX4 5.0
Cobra Jay is offline   Reply With Quote
Unread 04-02-2007, 03:27 AM   #3
blue83z
blue83z's Avatar
If the only cons are $ then Im getting one.Thanks.
Unread 04-02-2007, 05:40 PM   #4
blk00rt
blk00rt's Avatar
blk00rt I need rep points!
aluminum is lighter, I believe you can spin it more rpms...at certian lengths they force you to go aluminum due to rotating mass. Mine had to be 5" aluminum because steel would not last at 700 hp and 68" long drive shaft.
At least that is what the drive shaft shop told me.
Rob Dunn
2000 Dakota RT
12.2 @ 105 mph
blk00rt is offline   Reply With Quote
Unread 04-03-2007, 02:19 AM   #5
Cobra Jay
Semper Fi
Cobra Jay's Avatar
Yeah pretty much only thing is the cost if you can't find one for your car "Off the shelf". And the only reason is because the incrase in the price of aluminum in the past 3-4 years.
DTS can hook you up.
Unread 04-05-2007, 05:04 AM   #6
blue83z
blue83z's Avatar
Thanks.Im going with Mark williams,custom length 47"x3-1/2 Aluminum.Should be the last shaft I ever buy.800$ with yoke.
Unread 04-05-2007, 08:36 PM   #7
blk00rt
blk00rt's Avatar
damn..that seems high...mine was less than that for a 5" aluminum driveshaft 68" long.
Rob Dunn
2000 Dakota RT
12.2 @ 105 mph
Unread 04-06-2007, 01:42 AM   #8
Cobra Jay
Semper Fi
Cobra Jay's Avatar
No problem, but yeah that seems real high.
Did you try DTS? They can get custom shafts made. I had them do one for a 71 RR with a Koffels built 413 Max Wedge and it was good to handle 800 lbft. Don't rememeber what I paid but it was less than $500 for it.
Unread 04-06-2007, 01:42 PM   #9
blue83z
blue83z's Avatar
I know its high,but its good to 1200hp.Its not welded either,and its some special material aluminum prostocks use.Ive have alot of shaft problems in past.I guess its just piece of mind more than anything.Thanks
Unread 04-06-2007, 07:15 PM   #10
SloNotch
SloNotch I need rep points!
DTS sends their driveshafts to a place called CCI. You can save by going there directly.
89 Notch
SloNotch is offline   Reply With Quote
Unread 04-11-2007, 01:47 AM   #11
blue83z
blue83z's Avatar
Thats Camerons Cove.They are good and inexpensive,but they cant gaurentee me 1000 hp with aluminum.Neither can Dynotech.Mark williams is the onely one not worried about 1000HP.Dynotech said they cant get that metal matrix badass shit anymore for a while.they use just plain aluminum.
Unread 04-11-2007, 01:54 AM   #12
Cobra Jay
Semper Fi
Cobra Jay's Avatar
If they guarentee it's good for 1200hp, then you should be good to go. Especially with a Chebby.
Unread 07-01-2008, 01:00 AM   #13
camaromann
camaromann I need rep points!
wow! Mine is good to almost 2,000 hp and it is 3 1/2 inch 50 and 1/16 long steel 1350 series u-joint....paid just over $300 with a new slip yoke for a turbo 400. call CCI.
camaromann is offline   Reply With Quote
Unread 07-01-2008, 01:02 AM   #14
camaromann
To correct myself, my drive shaft can withstand almost 2,500 hp and will spin to 10,400rpm's.......not that it will ever see that..lol.
Unread 06-27-2010, 02:45 AM   #15
camaro1982
crying aint racing !
camaro1982's Avatar
camaro1982 I need rep points!
i'm running a 3 1/2 inch by 45 1/2 steel drive shaft with 1350 u-joints and almost 700hp and have had no problems. paid $290 from indiana driveline.
camaro1982 is offline   Reply With Quote
FS: Snows On Steel Wheels sickspd04 Classifieds 0 07-08-2006 09:33 AM
Fox alum. bumper support on ebay BigWheelinBubba The Alley 3 07-01-2005 05:22 PM
DriveShaft cobrafreak01 The Alley 5 03-18-2005 11:26 AM
