Go Back   Detroit Racing Forums > General Discussion > The Alley
Unread 05-15-2005, 06:07 PM   #1
silverknight
SLO = Shitty Low Output
silverknight's Avatar
silverknight I need rep points!
Default need install help
i just picked up some cool looking gauges from canada. and i want to install them soon. could someone help me install them? i have Water Temp, Volts, and Oil Pressure. and i might get a Tranny Temp Gauge soon. i could do the Volts myself, but dont know how to do the other 2 i currently have. i could drive to someones house.
thanks in advance
mario
Silver 95 Ford Taurus SE - 104k - modded
White 93 Ford Taurus SHO ATX - 108k - kinda stock
Blue 62 Caddy Sedan De'Ville - FOR SALE $2000firm
silverknight is offline   Reply With Quote
Unread 05-15-2005, 06:53 PM   #2
Strtracer
Retired
Strtracer's Avatar
Strtracer will become famous soon enoughStrtracer will become famous soon enough
Just a couple of tips for you.
1. do not use plastic tubing for your oil feed, at a minimum get the brass tubing kit from ramchargers or summit. The best would be -2 braided, but I understand budget is a consideration.
2. both the oil gauge and water temp gauge(unless they are electric) will have to pass thru the fire wall, try to find a factory hole, becarefull if you have to drill, check both sides for anything in the way. Insulate the edges of the whole,you can get rubber grommets at a hardware store.
3. You can download installation instructions at AutoMeter's page, the instructions are fairly universal for those 3 gauges, might want to check to see if your brand has a web site.
4. Your gonna have to fabricate 1 or 2 Tee's to hook those gauges up, so plan it out, then go to the hardware store, they should have the brass or steel fittings youll need.
Ban low performance Drivers,
Not High Performance Cars
Strtracer is offline   Reply With Quote
Unread 05-17-2005, 09:53 PM   #3
silverknight
thats how they look mounted in there
i like em
im not sure if thats the order they will stay in tho.
Unread 05-17-2005, 09:57 PM   #4
Strtracer
Retired
Strtracer's Avatar
Looks good
