Go Back   Detroit Racing Forums > RSS NewsFeeds > Dragzine Newsfeed
Unread 03-01-2011, 08:32 PM   #1
NewsBot
NewsBot I need rep points!
Default Keep Your Release Bearing Alive With The Ram Clutch Pedal Adjuster
Fine-tune clutch pedal heights on aftermarket or OEM systems with the Ram Clutch Pedal Adjuster. It can help erase problems with over-travel of the release bearing, which can control it and cause high RPM engagement problems.
More...
NewsBot is offline   Reply With Quote
Keep Your Release Bearing Alive With The Ram Clutch Pedal Adjuster NewsBot Dragzine Newsfeed 0 03-01-2011 07:44 PM
