» Sponsors |
Support Our Sponsors |
01-29-2009, 11:27 PM
#31
Originally Posted by Fryguy302
Detroitracing.com is paying contingency for any heads up Milan class. $25/runner up, $50 to win.
damn that is very cool of ya raj!
detroitracing.com ftw!
BANNED RACING
PORT HURON,MI.
01-29-2009, 11:37 PM
#32
Originally Posted by daveg
Thats cool. I had no clue they were that complex. I would be lost with that shit. This is the extent of my computer skills right here ...lol
yeah me too, i dont have a laptop that works it. i used a different one once just to set it up and i havent messed with it since then. only setup the retards and rpm limiters one time, you can download the program if your go to the msd site. its the 7531 box, you can see all the things you can adj, its crazy.
STREET DRIVEN DAILY, STREET RACED NIGHTLY
DETROIT STREET RACING DVD'S FOR SALE, PM ME IF INTERESTED
01-29-2009, 11:46 PM
#33
Thats a bad motherfucker. Datalogger and timing maps. That thing does everything we used to do with our right foot and a wrench. I must be gettiing old I remember when a playback tach was the shit...lol
01-29-2009, 11:50 PM
#34
everybody asks why i have my tach down on the floor where i cant see it, but i dont need to see it just the shift light. box does everything else. its cool, i got to learn how to do the "dots" now especially in this class.
01-30-2009, 12:21 AM
#35
You are going to need all your focus to keep it straight on that tiny tire.
Record: 5.36 @131.96 MPH 1/8th
Lets hope they dont make the trek out here any time soon. At least not till you guys have a chance to get the combos sorted out. Sounds like a fun class. Lets hope the guys with deep pockets dont feel like trophy hunting like they do in every other class and ruin it for the regular guys like most of you on this site.
01-30-2009, 06:30 AM
#36
1984 Capri. Finally at home, slowly coming together??
01-30-2009, 07:33 AM
#37
In the village
ModeratorMember
Originally Posted by Ridings Automatics
I wonder if they would let me run the hub caps?
No problem......................
As long as you screw them the the wheels !
01-30-2009, 07:56 AM
#38
Maybe a certain BBC might try this class out as well.whats the weight?
1st member of team B racing
01-30-2009, 08:44 AM
#39
Preliminary Rules Outlaw 8.5 January 15 2009, 4:13 PM
Body & Glass
-Stock appearing interior<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com ffice ffice" />
-Lexan windows allowed
- No wheelie bars
- Must Run Mufflers
Tires
Maximum rear slick allowed is 26 X 8.5 designation (9 as measured)
Tire must be used as intended from manufacturer. No alterations permitted. Slicks only. Commercially available tires only, no test tires.
Power Adders
Single type power adder only
Weights
Small block N/A 2800 lbs
Small block nitrous 3150 lbs
Small block turbo & supercharger - 3250
Big block N/A 3050 lbs
Big block nitrous 3250 lbs
Big block turbo & supercharger - 3350
Add 100lbs for multi-stage NOS
Deduct 50 lbs for non-intercooled forced induction engine
4 Cylinder deduct 500 lbs from small block weight
6 Cylinder deduct 300 lbs from small block weight
Buick, Pontiac and Oldsmobile OEM engine combinations run at small block weight. Aftermarket and/or aluminum blocks and parts as well as hybrid combos (example: BOP block with Chevy heads) are not eligible for weight break.
Chris Baxter
Race Director
01-30-2009, 08:52 AM
#40
Thanks Raj.
01-30-2009, 09:32 AM
#41
The rules that were on the other site....
Limited 8.5 class rules
Nitrous Power Adder Plate Type
Single Spray Bar Plate, Diffuser, Perimeter
.082 Conventional Head Small Block
.073 Conventional Head Big Block / Gen III SBC
.055 Non-Conventional Head Small Block / Big Block
Multiple Spray Bar Plate
.059 Conventional Head Small Block
.053 Conventional Head Big Block / Gen III SBC
.036 Non-Conventional Head Small Block / Big Block
Approved Plates
Any Single Spray Bar Plate
NOS Double Cross Plate (Approved P/N’s 02151 12565, 02152, 12665)
ZEX Perimeter Plate (Approved P/N’s 82043, 82040, 82048, 82072)
SpeedTech Diffuser Plate (Approved P/N’s 231-000, 231-010, 231-200,231-210)
NX Gemini Twin Spray Bar Plate (Approved P/N’s TBA)
MAX nitrous Supply Line from Bottle: -6AN
Additional nitrous systems may remain on the vehicle including all plumbing and wiring, but must be capped at the solenoids and wires unhooked or fogger nozzles can be left in manifold with caps.
Engine & Cylinder Heads
Single four barrel carburetor only
Single four barrel carburetor cast intake manifold only
No tunnel ram type intakes
No fabricated sheet metal intake manifolds allowed
No alcohol (gasoline only)
Fuel injection add 50lbs.
302 based combos deduct 75lbs on N/A ans NOS only
air to water cooler add 50lbs
Conventional Cylinder Head Definition
Any commercially available cylinder heads that maintains the original production engine cylinder head valve angles (+/- 3 degrees) and port layout.
Non Conventional Cylinder Head Definition
Any commercially available cylinder head that does not meet the specification of the conventional cylinder head definition. (Examples: 18/15 deg SBC GM, 18/17/16/15 deg Dart SBC, 18,16,15,13 deg Brodix SBC, 14/12 deg Pro-Action SBC, SBF Brodix Neal, SBF Victor, SBF Victor Glidden, SB2, Splayed/Canted Valve GM, SBF Bennett Canted Valve Ford, Chrysler P7, Aftermarket LS1/LS6 Heads, SBF Yates, SBF Pro-Kings, SBF Man-o-War, Big Chiefs, Big Dukes, Predator BBChry, PB Series Brodix BBC, SBF SC1, SBF D3, Brodix BD 2000/1010 SBC, Brodix GB Series SBC, BBC Raptor, BBC Profiler) If your cylinder head is not listed in the above examples, you must call ahead for clarification.
Weight Breaks
Nitrous Assisted
· 3200 lbs. Small block with nitrous
· 3400 lbs. Big block with nitrous
Forced Indution 76 mm turbo F1R YSI or smaller (SB only)
. 3250 lbs small block blower w/serpetine belt
. 3250 lbs small block 76mm turbo
. 3350 lbs small block blower w/ cog belt
Naturally Aspirated
· 2800 lbs. Small block N/A with conventional heads
· 2950 lbs. Small block N/A with non-conventional cylinder heads
· 3100 lbs. Big block N/A with conventional cylinder heads
· 3200 lbs. Big block N/A with non-conventional or non-wedge heads
Transmissions
· Any OEM type automatic or manual transmissions allowed.
· Add 150 lbs for non-OEM manual clutchless transmissions (Examples: G-Force, Liberty, Jerico)
· Aftermarket heavy-duty cases allowed
Suspension
· Aftermarket front suspension components allowed (must bolt-on in stock locations) Factory frame rails required on front of vehicles in stock position.
· Front coilover shocks allowed on non strut vehicles as long as shock is mounted to lower A arm in stock location.
· Aftermarket stock type rear suspension allowed (must bolt-on in stock locations) Factory frame rails required on rear of vehicles in stock position. (Small Mini-Tubs OK)
· Rear coilover shocks allowed
. ladder bars OK
· Leaf springs may be moved in-board
· Relocation of rear shock allowed
· No wheelie bars, four links allowed
· Anti-sway bars allowed
Tire
Spec tire 26x8.5 tire ONLY
Vehicle
Must have full stock appearing interior with dash and two front seats (no metal visible-must be carpeted)
Stock firewall must be retained and in stock location
Notching of firewall for clearance of bell housing and distributor is acceptable
Rack and pinion steering allowed
Rear seat may be removed
Windows must be operational
Lightweight body components limited to hood, trunk lid, and bumpers
Hoods are required on vehicles. (In the event of a hood blow-off during competition the vehicle will be allowed to remain in competition for the remainder of event without a hood as long as minimum weight is met. Must be fixed prior to next event)
Must have mufflers
Cars must be driven to staging lanes and cross scales after completion of a pass without towing.
01-30-2009, 11:15 AM
#42
Ridin Dirty
Cant wait to run this class !!! Whats the world turning to when johnnyquick has become a class racer
01-30-2009, 11:17 AM
#43
Ridin Dirty
I cant wait to see my car 4in lower with the small tires on it this year, should look sweet !!
01-30-2009, 12:09 PM
#44
im just chasin you around. you wouldnt race me at the no et deal so now i got to run 8.5 to get a race off with you.
01-30-2009, 12:14 PM
#45
No excuses when everyone is at weight and on the exact same tire. Should be fun.
Thread Tools |
Display Modes |
Linear Mode
» Links |
DR Links |
