Go Back   Detroit Racing Forums > General Discussion > The Alley
Unread 10-26-2006, 05:14 PM   #1
pferd
pferd's Avatar
pferd I need rep points!
Question What should a gear change go for?
I'm just starting to look around for a place to swap out the 3.31 gears on my Mustang with some 3.73s. I called the stealership, and they quoted me $650, not including the parts, which I would supply.
I know those guys are usually overpriced, but is that WAAAAAY over the top? What does a gear change go for around here?
pferd is offline   Reply With Quote
Unread 10-26-2006, 05:26 PM   #2
Do what I did, send a PM to Scott@DrivelineSolutions.
He'll give you a much better price, and he is very good at what he does!
(I also happen to know he working on 05+ mustangs... )
Unread 10-26-2006, 08:29 PM   #3
blk00rt
blk00rt's Avatar
blk00rt I need rep points!
I had mine done for about 250.00 plus gears and install kit at DTS on Grosebeck.
Rob Dunn
2000 Dakota RT
12.2 @ 105 mph
blk00rt is offline   Reply With Quote
Unread 10-26-2006, 08:53 PM   #4
Boomer!
Infraction Jackson !!!!!!
Boomer!'s Avatar
Location: Wandering my empty garage moving parts 10' at a time
Boomer! I need rep points!
Had mine done for $175 but I won't advertise here...
Build cars from a "book" when I can't even read
HOOC'd on Foniks wurkt foor me
Boomer! is offline   Reply With Quote
Unread 10-26-2006, 08:57 PM   #5
Lisa
This is my title!
Lisa's Avatar
Lisa people like meLisa people like meLisa people like meLisa people like meLisa people like meLisa people like meLisa people like meLisa people like me
Yeah, $650 is a lot.
Call Scott at Driveline...he's very reasonable and does great work.
Yeah, well my car has a heated steering wheel!
Lisa is offline   Reply With Quote
Unread 10-26-2006, 10:06 PM   #6
Blade7764
Always ready
Blade7764's Avatar
Blade7764 I need rep points!
do 4.10s!!!!!!!!!
Blade7764 is offline   Reply With Quote
Unread 10-27-2006, 05:37 AM   #7
Yeah, be like Lars.
Unread 10-27-2006, 07:45 AM   #8
I'd give Scott a call. BTW I agree, go with 4:10's!
Unread 10-27-2006, 08:05 AM   #9
Wait wait wait! You have 3.31s? That mean you have an automatic? Or did they put 3.31s in the manuals in 07?
For the 05+ automatics, 4.10s do not work very well. You'll want to leave it stock and get a higher stall converter for some real fun.
I tried 4.10s myself, gained about 1/10th Then I decided to go back to almost stock (3.55s) and get a TCI converter (about 3800 stall) and gained another 6/10ths. I'm sure if I still had my stock 3.31s it'd be very close to what it is now.
With the tune from Lidio, the high stall really isn't bad for daily driving. Lockup in 5th gear only, at 62MPH, or 40MPH if cruise control is on. If you drive alot and care about MPG, it dropped from 21 to 17 with 4.10s and got back up to 19-20 with 3.55s and converter with my mix of city/highway.
Unread 10-27-2006, 09:36 AM   #10
pferd
pferd's Avatar
Yikes, I guess I'll steer clear of the dealer!
Yes, I have 3.31s on my automatic. The 07 manual comes with 3.31 stock as well, I am supposing for MPG sake.
What is the stock torque converter on the 05+? I haven't read how a high stall can work with the lower gearing to give you better take off speed. Time to google....
I was tempted by the 4.10, but a few of my assumptions pointed to the 3.73s:
-Higher RPMs at highway speed, which I wasn't comfortable with
-Lower mileage
-More whine/noise than lower gears
-I heard 4.10s are less effective with blown engines, which is where I'm eventually heading
Unread 10-27-2006, 09:56 AM   #11
Hmm.. I think I'd wait and do the blower install before changing any gears or converter, that way it'll be easier to pick the right setup for the type of blower you get.. unless the blower is a couple years off, then I'd get an n/a friendly converter now.
I don't remember the exact specs on the stock converter, but at least that's easy to test yourself.
Unread 10-27-2006, 01:57 PM   #12
pferd
pferd's Avatar
lab,
Been reading up on torque coverters....With the higher performance on your converter and the resulting higher temp, did you make sure to get a tranny cooler installed as well?
Unread 10-27-2006, 02:28 PM   #13
Nope, Lidio told me the stock cooler is pretty good on these cars and it can handle the higher stall converter.
Unread 10-27-2006, 03:39 PM   #14
Scott_DriveLineSolutions
Offically an 8 second car
Scott_DriveLineSolutions's Avatar
Scott_DriveLineSolutions I need rep points!
DTS is where I started back in 1994.
Scott_DriveLineSolutions is offline   Reply With Quote
Unread 10-28-2006, 07:06 AM   #15
blk00rt
blk00rt's Avatar
scott,can you get custom driveshafts at a good price?I may need to change mine out this winter..email me at black00rt@yahoo.com and I can give you details.thanks
Rob Dunn
2000 Dakota RT
12.2 @ 105 mph
Question on calculating RPM at given speed x gear 99SVTAddict The Alley 9 09-26-2005 04:15 PM
Motive Gear GP Scott_DriveLineSolutions The Alley 0 08-14-2005 11:37 PM
C5 Gear swap Scott_DriveLineSolutions The Alley 2 07-23-2005 11:41 AM
3:73 Gear For 7.5" Mustang Rearend 357windsor Classifieds 1 04-04-2005 10:38 PM
Figured id change it up a bit.... firebird355 The Alley 16 03-08-2005 11:01 AM
