Go Back   Detroit Racing Forums > Technical Discussion > The Shop
Unread 09-06-2005, 12:16 PM   #1
cobrafreak01
Do-it-yourself-er
cobrafreak01 I need rep points!
Default Trans Question
I came accross a used T56 out a 1994 Camaro. The trans was rebuilt, installed, driven a couple miles, and locked up due to no fluid. (Oops)
My guess is that the bearings are all cooked. But my question is has anyone on here ever heard of anyone installing this trans into a 99+ mustang? What was involved if so? I am sure I am going to need to change the input and output shafts to mee the proper lengths and splining.
Already called D&D and they offer no conversion kits for this trans.
cobrafreak01 is offline   Reply With Quote
Unread 09-06-2005, 12:37 PM   #2
Strtracer
Retired
Strtracer's Avatar
Strtracer will become famous soon enoughStrtracer will become famous soon enough
You can expect major damage inside that trans, although the bearings will be cooked, it is more likely that the gears have severe heat damage to them, and that is why the trans wont spin.
As far as installing it in a Mustang, its put together entirely wrong. Its case is designed to be mounter on an angle( tilted towards the driver), and the shifter location is wrong.
Best bet would be to see if its repairable at a reasonable cost, then trade it for the correct trans
Ban low performance Drivers,
Not High Performance Cars
Strtracer is offline   Reply With Quote
Unread 09-06-2005, 03:19 PM   #3
What he said.
Unread 09-06-2005, 11:56 PM   #4
Fordgazm
Fordgazm's Avatar
Fordgazm I need rep points!
Aint all chevys ?
I have a bunch of parts from a 92 gt in the garage , I guess I'll call it a car
Fordgazm is offline   Reply With Quote
Unread 09-07-2005, 07:27 AM   #5
cobrafreak01
Do-it-yourself-er
Thanks for the help guys.
Unread 09-07-2005, 03:45 PM   #6
Originally Posted by Fordgazm
Aint all chevys ?
water pump question 88lxbrian The Shop 1 05-27-2005 06:04 PM
Spring event question 99SVTAddict The Alley 14 04-13-2005 10:48 AM
Motor & Trans is in!!!!!!!!!!!!! 1Quick88 The Alley 27 04-04-2005 07:25 AM
trans front seal silverknight The Shop 4 04-02-2005 04:21 PM
Wheel Question 357windsor The Shop 5 03-20-2005 08:05 AM
