Go Back   Detroit Racing Forums > Technical Discussion > The Shop
Unread 06-19-2005, 01:27 PM   #1
99TransAmWs6
Hmmmm...
99TransAmWs6's Avatar
99TransAmWs6 I need rep points!
Default Buddys Car Is Throwing A Code (FORD)
We were on our way out to gratiot yesterday to park at the lot..and as he turned to corner his car kinda sputtered and then just completely shut off. I could not get it to turn over..it would crank..but never turn. His odometer was reading "- - - - - -" I disconnected the pcm..pulled his chip...did the battery disconnect and still nothing. We finally get a code off of it..and its a P1633. Which comes out to be a "Keep Alive Memory power voltage too low" I have no idea what that is..im thinking its something with the PCM or electrical...any ideas on where to look though? Its a 2000 Mustang Saleen.
-Cory
1999 Trans Am WS6
Street racing to some people equals 10% racing....90% trash talking.
99TransAmWs6 is offline   Reply With Quote
Unread 06-19-2005, 01:58 PM   #2
i just did a quick search and found this out..not sure if it helps u much but atleast its a start.. http://forums.corner-carvers.com/arc...hp/t-2995.html the first few posts talk about it
Unread 06-20-2005, 09:51 PM   #3
HemiChallenger
HemiChallenger I need rep points!
Sounds like a dead battery caused by a dead altinator. Just a guess though.
HemiChallenger is offline   Reply With Quote
Unread 06-29-2005, 06:11 AM   #4
Default Problem
Your buddy ever figure out what the problem was?
Unread 06-29-2005, 07:23 AM   #5
Not yet. The battery is new and volt meter shows 14+ amps...when it does fire up.
Unread 06-29-2005, 09:03 AM   #6
That sucks. Hope you find out what's wrong w/ it. I'll try to find some info on it too.
Unread 06-29-2005, 09:09 AM   #7
Actually, Cory talked to Rob the other day and Rob thinks he knows what's wrong. Here's what Cory said about this over on MM...
Originally Posted by 99TransAmWS6
Robs already found out that it is blowing a fuse everytime the car gets up in R's. Somethign to do with his harness...once we get time..im gonna pull his harness out and take a look at it. He said a couple yrs ago..his tire rubbed the harnes..and strayed some of the wires which he fixed. Im gonna solder it all and hopefully that'll take care of it
Unread 06-29-2005, 10:36 AM   #8
1BadRoushChick
Don't try...
1BadRoushChick's Avatar
1BadRoushChick I need rep points!
Yeah seeing that all those wires run through that front left tire well, they need to be soldered and hidden away so that nothing can effect them...it's like a rats' nest under there.
J.a.C.q.U.i.E.
Motor-City Powerhouse C.C.
1BadRoushChick is offline   Reply With Quote
