12 bolt / rear driveshaft loop pics
I am fabbing my rear driveshaft loop for our Nova with a 12 bolt axle , now the 9" axle is easy because the rear driveshaft loop bolts to the pinion support ,but on the cars with 12 bolts ??? post pics if you would ,thank you .
finished the fab work !
4 Attachment(s)
Here is my rear driveshaft loop (painted white to be seen under the car) and the front driveshaft loop welded to a hoop that was installed originally.
